ผู้เขียน หัวข้อ: Import-Export Desiccant Masterbatch , Masterbatch manufacturer price.  (อ่าน 60 ครั้ง)
polychemicals10
  • Full Member
  • กระทู้: 158
« เมื่อ: เมื่อวานนี้ เวลา 01:38:59 AM »
Distribute Moisture Absorber, Industrial chemicals
Anti-moisture Masterbatch, Desiccant Masterbatch ,
Moisture Absorber Distribute plastic moisture barrier,
MAP Masterbatch, Moisture Absorber barrier company,
Wholesale plastic moisture absorbent, เม็ดดูดความชื้น ,
Cheap Desiccant Masterbatch, Anti-moisture Masterbatch at wholesale price,
Distribute MAP Masterbatch, Moisture Absorber factory,
Plastic moisture barrier company, Import plastic moisture barrier,
Export plastic moisture absorber, Production of plastic
Import-Export plastic moisture barrier,
Plastic moisture barrier company. Wholesale Desiccant Masterbatch .
Thai Poly Chemicals Company (Plastic Additive)
TPCC PKSN PLASTIC ADDITIVE THAILAND
FW_Desiccant Masterbatch_PKSN 15032025
Import plastic moisture barrier at factory price,
Export plastic moisture barrier at wholesale price,
Plastic moisture barrier factory, Plastic moisture barrier company,
Plastic moisture absorbent, Masterbatch,
Tel 0893128888
Produce plastic moisture barrier at factory price, Plastic defoaming resin
MAP Masterbatch, Moisture Absorber, Moisture Absorber Resin
Distribute plastic moisture barrier at cheap price, plastic moisture barrier factory,
Plastic moisture barrier company Wholesale Moisture
Absorber at factory price, Chemical shop, Moisture Absorber at manufacturer price,
Antifoam desiccant additive, Antifoam desiccant granules
Antifoam desiccant masterbatch, Antifoam desiccant resin
Anti-moisture additive, Anti-moisture granules, Anti-moisture masterbatch
Anti-moisture resin, Desiccant additive, Desiccant granules,
Desiccant masterbatch, Desiccant resin, MAP additive
MAP granules, MAP masterbatch, MAP resin, Moisture absorbent additive
Moisture absorbent granules, Moisture absorbent masterbatch
Moisture absorbent resin, Moisture absorber additive
Moisture absorber granules, Moisture absorber masterbatch,
Moisture absorber resin, Moisturized absorb plastic additive
Moisturized absorb plastic granules, Moisturized absorb plastic masterbatch
Moisturized absorb plastic resin, Moisturized absorbing plastic additive
Moisturized absorbing plastic granules, Moisturized absorbing plastic masterbatch
Moisturized absorbing plastic resin, Plastic defoaming additive
Plastic defoaming agent, Plastic defoaming granules, Plastic defoaming masterbatch
keywords : plastic moisture barrier,
Plastic moisture barrier company. Desiccant Masterbatch,
Anti-moisture Masterbatch, MAP Masterbatch สารเคมีอุตสาหกรรม,
เม็ดกันชื้น, Desiccant Masterbatch , Desiccant Masterbatch
เม็ดดูดความชื้น, เม็ดกันชื้น, Anti-moisture Masterbatch,
เม็ดกันชื้นในพลาสติก,  Desiccant Masterbatch MAP Masterbatch,
Factory price MAP Masterbatch seller, Cheap Desiccant Masterbatch Chemical
distributor Moisture Absorber for industry, Distribute Moisture Absorber wholesale price,
Where to find Moisture Absorber, Import - Export MAP Masterbatch,
Desiccant Masterbatch How much does it cost, Moisture Absorber Factory price,
Desiccant Masterbatch MAP Masterbatch, Factory price,
Masterbatch Distribute Desiccant Masterbatch
chemicals for industry Distribute ,plastic moisture absorber pellets,
Plastic moisture absorber pellet factory, Plastic moisture absorber pellet company
Plastic desiccant pellets, import-export ,Plastic moisture absorber beads,
Import plastic moisture absorber beads, Export plastic moisture absorber beads,
Produce plastic moisture absorber beads, Distribute plastic moisture absorber beads,
Plastic moisture absorber beads factory, Desiccant Masterbatch, Anti-moisture Masterbatch,
MAP Masterbatch, Moisture Absorber, Wholesale Desiccant Masterbatch Where to find,
MAP Masterbatch, MAP Masterbatch, Moisture Absorber Desiccant Masterbatch
Wholesale MAP Masterbatch Manufacturer price, Import plastic moisture absorber beads,
Export plastic moisture absorber beads, Produce plastic moisture absorber beads,
Distribute plastic moisture absorber beads, Plastic moisture absorber beads factory
Desiccant Masterbatch factory, Moisture Absorber wholesale price,
Thailand Desiccant Masterbatch, Anti-moisture Masterbatch from factory,
Desiccant Masterbatch distributor , Anti-moisture Masterbatch,
Cheap Desiccant Masterbatch exporter, Wholesale Moisture Absorber manufacturer,
Export plastic moisture barrier, Anti-moisture
Produce plastic moisture barrier, MAP Masterbatch,
Distribute plastic moisture barrier, Moisture Absorber,
moisture barrier pellets, distribution of plastic
moisture barrier pellets, plastic moisture barrier factory,
บริษัทเม็ดกันชื้นในพลาสติก, นำเข้าเม็ดกันชื้นในพลาสติก,
ส่งออกเม็ดกันชื้นในพลาสติก, ผลิตเม็ดกันชื้นในพลาสติก,
ขายDesiccant Masterbatch  ร้านขายเคมีภัณฑ์ Desiccant Masterbatch
export of plastic moisture barrier pellets, production of plastic moisture barrier pellets,
where to buy MAP Masterbatch, industrial plastic
moisture barrier pellets, wholesale plastic moisture
absorbent pellets, Desiccant Masterbatch,
export Anti-moisture Masterbatch at factory price,
import MAP Masterbatch, Moisture Absorber at wholesale price,
MAP Masterbatch seller, distribution of Moisture
Absorber at cheap price, wholesale MAP Masterbatch,
MAP Masterbatch factory, Anti-moisture Masterbatch,
Moisture Absorber at manufacturer's direct price,
Desiccant Masterbatch, MAP Masterbatch, MAP Masterbatch,
Moisture Absorber, chemical factory, plastic moisture
absorbent pellets for industry , Where to find plastic moisture absorbent pellets?
How much does Anti-moisture Masterbatch cost?
Wholesale MAP Masterbatch, Plastic moisture absorbent
pellets Wholesale price Sell Desiccant Masterbatch Chemical shop
Desiccant Masterbatch Distribute , Wholesale MAP Masterbatch for industry,
Moisture Absorber manufacturer price
Desiccant Masterbatch ราคาถูก, Anti-moisture Masterbatch ราคาส่ง,
จำหน่าย MAP Masterbatch, โรงงานผลิต Moisture Absorber,
บริษัท ไทยโพลีเคมิคอล จำกัด (พลาสติกแอดดิทีฟ)
Anti-moisture Masterbatch, Desiccant Masterbatch,
MAP Masterbatch, Moisture Absorber Resin
เม็ดกันชื้น, Desiccant Masterbatch, เม็ดดูดความชื้น,
Anti-moisture Masterbatch, เม็ดกันชื้นในพลาสติก, เม็ดดูดความชื้นในพลาสติก
ประโยชน์ของ เม็ดกันชื้น
ช่วยแก้ปัญหาความชื้นในพลาสติก, ช่วยลดอัตราสูญเสียของการผลิตอันเนื่องมาจากความชื้น, ช่วยเพิ่มประสิทธิภาพการผลิต, ช่วยเพิ่มกำลังการผลิต, ช่วยลดการสิ้นเปลืองพลังงานอันเกี่ยวเนื่องกับกระบวนการผลิตพลาสติก รวมทั้งช่วยลดต้นทุนการผลิตโดยรวม
การใช้งาน เม็ดกันชื้น
สามารถใช้ผสมกับเม็ดพลาสติกรีไซเคิล และเม็ดพลาสติกที่มีความชื้น เพื่อลดความชื้นในพลาสติก
อัตราส่วนการผสม เม็ดกันชื้น
ผสมเม็ดกันชื้น ในอัตราส่วน 1% - 4% ขึ้นกับความชื้น และลักษณะของเม็ดพลาสติกที่ต้องการผสม
มาตรฐานการบรรจุ เม็ดกันชื้น
บรรจุในถุงสุญญากาศ  5 กิโลกรัม ต่อ ถุง ใน 1 กล่องมี 5 ถุง ( 25 กิโลกรัม ต่อ กล่อง)
วิธีการเก็บรักษา เม็ดกันชื้น
เก็บเม็ดกันชื้นในที่แห้ง และมีการระบายอากาศที่ดี หลีกเลี่ยงการโดนแสงแดด สินค้าต้องเก็บในสภาพสุญญากาศตลอดเวลา หากพบสินค้าไม่อยู่ในสภาพสุญญากาศ ต้องรีบแจ้งกลับมายังบริษัท ฯ เพื่อนำสินค้าใหม่ไปเปลี่ยนให้ เพื่อการใช้งานเม็ดกันชื้น ได้อย่างมีประสิทธิภาพ
ข้อควรระวังการใช้งาน เม็ดกันชื้น
หากผสมเม็ดกันชื้น กับเม็ดพลาสติกเรียบร้อยแล้ว ต้องทำการผลิตในทันที หรืออย่างน้อยต้องทำการผลิตภายใน 8-24 ชั่วโมง ไม่ควรเก็บข้ามวันหรือเก็บไว้ข้ามคืน เพื่อประสิทธิภาพการผลิตที่ดีที่สุดแนะนำให้ใช้ให้หมดภายใน 8 ชั่วโมง หลังจากเปิดถุงสุญญากาศ มิเช่นนั้นอาจทำให้มีปัญหาในการผลิตได้ และควรใช้สินค้าให้หมดภายใน 2 เดือน นับจากวันสั่งซื้อสินค้า แนะนำให้สั่งสินค้าในปริมาณที่สอดคล้องกับกำลังการผลิต ข้อมูลเพิ่มเติมเกี่ยวกับสินค้า เม็ดกันชื้น สำหรับงานพลาสติก สามารถสอบถามได้โดยตรงที่ ฝ่ายขายและการตลาด บริษัท ไทยโพลีเคมิคอล จำกัด
นอกจากมาสเตอร์แบทช์ เม็ดกันชื้น แล้ว บริษัท ยังจัดจำหน่าย
มาสเตอร์แบทช์ สำหรับอุตสาหกรรมพลาสติก รายการอื่น ๆ ด้วย อาทิเช่น
Antioxidant Masterbatch, แอนตี้ออกซิแดนท์ มาสเตอร์แบทช์, เม็ดกันเสื่อม
Anti-slip Masterbatch, แอนตี้สลิป มาสเตอร์แบทช์, เม็ดกันลื่น
Anti-static Masterbatch, แอนตี้สเตติก มาสเตอร์แบทช์, เม็ดกันไฟฟ้าสถิต
Calcium Carbonate Masterbatch, แคลเซียมคาร์บอเนต มาสเตอร์แบทช์, เม็ดแคลเซียม
Optical Brightener Masterbatch, ออพติคอลไบรเทนเนอร์ มาสเตอร์แบทช์, เม็ดกัดขาว
Purging Masterbatch, เพิร์จจิ้ง มาสเตอร์แบทช์, เม็ดล้างสกรู
Talcum Masterbatch, ทัลคัม มาสเตอร์แบทช์, เม็ดทัลคัม
UV Absorber Masterbatch, ยูวีแอพซอร์บเบอร์ มาสเตอร์แบทช์, เม็ดดูดซับรังสียูวี
UV Stabilizer Masterbatch, ยูวี สเตบิไลเซอร์ มาสเตอร์แบทช์, เม็ดป้องกันรังสียูวี
White Masterbatch, มาสเตอร์แบทช์สีขาว, เม็ดสีขาว, แม่สีขาว
Black Masterbatch, มาสเตอร์แบทช์สีดำ, เม็ดสีดำ, แม่สีดำ
Color Masterbatch, มาสเตอร์แบทช์สี, เม็ดสี, แม่สีสำหรับพลาสติก
Additive Masterbatch, แอดดิทีฟ มาสเตอร์แบทช์, เม็ดสารเติมแต่ง
Filler Masterbatch, ฟิลเลอร์ มาสเตอร์แบทช์, เม็ดฟิลเลอร์
Special Effect Masterbatch, มาสเตอร์แบทช์ ชนิดพิเศษอื่น ๆ
Moisturized Absorb Plastic Additive, MAP, Desiccant Masterbatch
Advantages
Solving problem of moisture in finished plastic product. Reduce reject percentage. Improve product quality and productivity. Reduce supplied energy. Optimized production cost
Properties
Desiccant masterbatch has been researched and developed specially for the moisture problem solving. It can absorb the moisture in plastic greatly without bringing quality down. The costs can be cut down and the productivity can be raised accordingly. It is widely used in recycle material, recycle plastic, moisturized plastic and degradable plastics. Normally the recycle material or recycle plastic contains a lot moisture.
Dosage
1% - 4%, depending on % of moisture content of raw material. Directly mix with plastic resin, plastic scrap
Applications
Used in recycle material, moisturized plastic and degradable plastics
Packing
25 kg per carton box (5 kg in vacuum PP bag, 5 bags per carton box)
Storage
Storage in dry area and good ventilation place, avoid sunlight, must keep in vacuum condition. After tearing off the vacuum bag, it is usable within 8-24 hours depending on the climate condition. But it's highly recommended to use within 8 hours for best productivity
Additional Information
More information of Desiccant masterbatch (Moisturized absorb plastic additive)
More information of additive masterbatch, filler masterbatch, plastic masterbatch
Please contact Thai Poly Chemicals Company Limited, Thailand
คำค้นหาสินค้า
เม็ดกันชื้น, สารกันชื้น, เรซินกันชื้น, เม็ดกันความชื้น, สารกันความชื้น
เม็ดดูดความชื้นในพลาสติก หาได้จากไหน   Anti-moisture Masterbatch ราคากี่บาท
Anti-moisture Masterbatch, เม็ดกันชื้นในพลาสติก, เม็ดดูดความชื้นในพลาสติก,
MAP Masterbatch, Moisture Absorber, นำเข้าเม็ดกันชื้น, ส่งออกเม็ดกันชื้น,
ผลิตเม็ดกันชื้นในพลาสติก ราคาโรงงาน, ส่งออกเม็ดกันชื้นในพลาสติก ราคาส่ง,
ผลิตเม็ดกันชื้นในพลาสติก ราคาโรงงาน, จำหน่ายเม็ดกันชื้นในพลาสติก ราคาถูก,
โรงงานเม็ดกันชื้นในพลาสติก, บริษัทเม็ดกันชื้นในพลาสติก, จำหน่ายเม็ดกันชื้น,
โรงงานเม็ดกันชื้น, บริษัทเม็ดกันชื้น, ขายส่ง MAP Masterbatch ,
เม็ดดูดความชื้นในพลาสติก ราคาขายส่ง, เรซินกันความชื้น,
เม็ดดูดความชื้น, สารดูดความชื้น, เรซินดูดความชื้น,  สารกันความชื้นในพลาสติก
มาสเตอร์แบทช์กันชื้น, มาสเตอร์แบทช์กันความชื้น, มาสเตอร์แบทช์ดูดความชื้น
เม็ดกันชื้นในพลาสติก, เม็ดกันความชื้นในพลาสติก, สารกันชื้นในพลาสติก,
เม็ดดูดความชื้นในพลาสติก, สารดูดความชื้นในพลาสติก, เม็ดกันชื้นสำหรับพลาสติก
เม็ดกันความชื้นสำหรับพลาสติก, สารกันชื้นสำหรับพลาสติก,
สารกันความชื้นสำหรับพลาสติก, สารดูดความชื้นสำหรับพลาสติก
เม็ดดูดความชื้น, เม็ดกันชื้น, Thailand Desiccant Masterbatch distributor,
Desiccant Masterbatch factory, Thailand Moisture Absorber, Desiccant Masterbatch ,
Desiccant Masterbatch Anti-moisture , Masterbatch production wholesale price,
buy Desiccant Masterbatch Anti-moisture , Masterbatch manufacturer price,
import-export Desiccant Masterbatch , Anti-moisture Masterbatch wholesale price,
export Desiccant Masterbatch , Anti-moisture Masterbatch cheap price
polychemicals10
  • Full Member
  • กระทู้: 158
Re: Import-Export Desiccant Masterbatch , Masterbatch manufacturer price.
« ตอบกลับ #1 เมื่อ: วันนี้ เวลา 05:39:18 PM »
17 มี.ค. 2025
22:48
Today : 86811
Total : 69876966
